StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD
£48.66
Delivery:
Standard: 1-3 working days
  • Type: HDD docking station
  • HD Size: 3.5, 2.5
  • Power Supply: Power adapter
Product codes
chevron icon
chevron icon
Enable fast, swappable access to your 2.5in or 3.5in SATA hard drives, through USB 3.0.
The SATDOCKU3S USB 3.0 Hard Drive Docking Station delivers full, instant access to any 2.5in or 3.5in SATA (SATA, SATA II, SATA III) hard drive (HDD) or solid state drive (SSD), without having to mount the drive in a computer or install it in an external enclosure. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities.
Connected to the host computer through a single USB 3.0 SuperSpeed or USB 2.0 connection, the hard drive docking station provides a convenient, plug-and-play storage solution that delivers instant access to the hard drive without requiring a reboot.
Relying on the outstanding data throughput support of USB 3.0, the HDD docking station is capable of transfer speed up 5Gbps, making it the fastest way to access data from an external drive. Double the value of this hard drive docking station, using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
chevron icon
Product Description StarTech.com SuperSpeed USB 3.0 to SATA Hard Drive Docking station for 2.5/3.5 HDD - HDD Docking station - SATA Dock - HDD docking station - SATA 3Gb/s - USB 3.0
Device Type HDD docking station - external
Bays 1
Bus Type USB 3.0
Colour Black
Expansion Bays 1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility 2.5", 3.5"
Interface SATA 3Gb/s
Data Transfer Rate 3 Gbit/s
Supported Devices Hard drive
Power Source Included AC adapter
Power AC 120/230 V
System Requirements Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows 7, Microsoft Windows Vista / 2000 / XP, Microsoft Windows Server 2008
Dimensions (WxDxH) 9.3 cm x 14.5 cm x 6.5 cm
Weight 410 g
Designed For P/N: PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, SAT2IDEADP, SVA12M2NEUA, SVA12M5NA, USB3SAB1, USBDUP15, USBDUPE115, USBDUPE17
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£48.66
