Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH10GR Cat 6 Patch Cable (10 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Product Description | StarTech.com 10ft CAT6 Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Cat 6 Patch Cord, 10GbE UTP CAT6 Network Cable, Gray CAT6 Ethernet Cable, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATCH10GR) - patch cable - 3 m - grey | Type | Patch cable - CAT 6 | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Molded, snagless | Length | 3 m | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: US1GC30A |
General | |
Network Cable Type | Patch cable - CAT 6 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Length | 3 m |
Colour | Grey |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL, RoHS, ETL - up to 650 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
