Don't wait to watch. Enjoy an ultra-smooth, lag-free Wi-Fi experience for Ultra HD video streaming and VR gaming.
Product Description | NETGEAR Nighthawk X10 - wireless router - Wi-Fi 5, 802.11ad (WiGig) - desktop | Device Type | Wireless router - 6-port switch (integrated) | Enclosure Type | Desktop | WAN Ports Qty | 1 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, IEEE 802.11ad (WiGig) | Frequency Band | 2.4 GHz / 5 GHz / 60 GHz | Data Transfer Rate | 7.2 Gbps | Features | Firewall protection, NAT support, VPN support, SPI, DoS attack prevention, IPv6 support, parental control, FTP server, Beamforming+, AirPrint support, MU-MIMO technology, Link Aggregation, Plex Media Server, Circle Smart Parental Controls | Compliant Standards | IEEE 802.11ac, IEEE 802.11ad | Dimensions (WxDxH) | 22.4 cm x 16.8 cm x 7.4 cm | Weight | 1.865 kg | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA-PSK, WPA2-PSK |
Processor | 1.7 GHz |
RAM | 1 GB |
Flash Memory | 512 MB |
Expansion / Connectivity | |
Interfaces | LAN: 6 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 1 x 10Gb Ethernet - SFP+ , USB 3.0: 2 x 9 pin USB Type A |
Aerial | |
Aerial | External detachable |
Antenna Qty | 4 |
Power | |
Power Device | External power adapter |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10 |
Dimensions & Weight | |
Width | 22.4 cm |
Depth | 16.8 cm |
Height | 7.4 cm |
Weight | 1.865 kg |
