The Mavic Car Charger is used to charge the Intelligent Flight Battery through a car's cigarette lighter port. It comes with low-voltage protection to ensure enough starting battery voltage for the car. Overheating protection will automatically cut off charging if your cigarette lighter port exceeds a certain temperature.
Product Description | DJI C3S78 car battery charger - 78 Watt | Product Type | Car battery charger | Voltage Required | 12.3 - 16 / 25 - 30 V | Voltage Provided | 13.05 V | Max Electric Current | 6 A | Power Provided | 78 Watt | Designed For | Mavic Pro |
General | |
Designed For | Drone |
Power Device | |
Input Connectors | Automobile cigarette lighter |
Input Connectors Qty | 1 |
Features | Overheat protection, low voltage protection |
Compatibility Information | |
Designed For | DJI Mavic Pro |
