The DES-3200 Series is a member of D-Link's Layer 2 managed switch family designed for the ETTX, FTTX, and enterprise markets. The DES-3200 Series provides 8/16/24, or 48 10/100 Mbps Fast Ethernet connections and various SFP or combo Gigabit/SFP ports uplink, as well as PoE options.
Product Description | D-Link xStack DES-3200-28P - switch - 24 ports - Managed - rack-mountable | Device Type | Switch - 24 ports - Managed - stackable | Enclosure Type | Rack-mountable 1U | Subtype | Fast Ethernet | Ports | 24 x 10/100 (PoE) + 2 x SFP + 2 x combo Gigabit SFP | Power Over Ethernet (PoE) | PoE | Performance | Switching capacity: 12.8 Gbps , Forwarding performance (64-byte packet size): 9.5 Mpps | MAC Address Table Size | 16K entries | Jumbo Frame Support | 12KB | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH-2, CLI | Features | Flow control, Layer 2 switching, DHCP support, PoE, BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, traffic shaping, DoS attack prevention, port mirroring, manageable, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, tunnelling, DHCP snooping, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping, Safeguard Engine | Compliant Standards | IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.3at | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44.1 cm x 30.8 cm x 4.4 cm | Weight | 4.2 kg |
General | |
Max Units In A Stack | 32 |
Encryption Algorithm | SSL, SSL 3.0, SSL 2.0 |
Authentication Method | RADIUS, TACACS+, Secure Shell v.2 (SSH2) |
RAM | 128 MB DDR2 SDRAM |
Flash Memory | 32 MB |
Status Indicators | Port transmission speed, power, link/activity, console |
Expansion / Connectivity | |
Interfaces | 24 x 100Base-TX RJ-45 PoE , 2 x 1000Base-T RJ-45 , 1 x console - RJ-45 , 4 x SFP (mini-GBIC) |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 250.78 Watt |
Miscellaneous | |
MTBF | 216,780 hours |
Compliant Standards | FCC Class A certified, UL, cUL, VCCI Class A ITE, CB, IC |
Dimensions & Weight | |
Width | 44.1 cm |
Depth | 30.8 cm |
Height | 4.4 cm |
Weight | 4.2 kg |
Environmental Parameters | |
Min Operating Temperature | -5 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 10 - 95% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 95% (non-condensing) |
