We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The HDMI to DisplayPort Adapter Converter allows you to connect an HDMI source device, such as your laptop or Blu-ray player, to a monitor or display with a DisplayPort input, delivering high quality video up to a maximum resolution of 1920x1200. This Converter is the perfect solution for connecting older HDMI-enabled devices that do not support a DisplayPort output to more modern, DisplayPort-equipped monitors and displays; a functionality that is not supported by other adapters that are designed to connect the DisplayPort output of a device to a display which accepts an HDMI input. Additionally, this converter supports HDCP.
Product Description | C2G HDMI to DisplayPort Converter - video converter - black | Device Type | Video converter | Max Resolution | 1920 x 1200 | Interfaces | 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort | Dimensions (WxDxH) | 8.15 cm x 4.2 cm x 2.3 cm | Enclosure Colour | Black | Manufacturer Warranty | 1-year warranty |
General | |
Features | HDCP |
System Requirements | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Miscellaneous | |
Compliant Standards | RoHS2 |
Width | 8.15 cm |
Depth | 4.2 cm |
Height | 2.3 cm |
Weight | 367 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 50 °C |
