We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
Product Description | C2G 5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI cable with Ethernet - 5 m | Cable | HDMI cable with Ethernet | Technology | Shielded | American Wire Gauge (AWG) | 28 | Length | 5 m | Colour | Black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | HDMI cable with Ethernet |
Jacket Material | PVC |
Shielding Material | Aluminium foil with braid |
Impedance | 100 Ohm |
Length | 5 m |
Plated Connector | Gold |
Colour | Black |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | UL |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
