High-speed IEEE-1284 compliant cables from C2G ensure you realize the added speed and two-way communications offered by your printers, HP tape drives, Iomega devices, scanners and more. This advanced technology, which defines high-speed, bi-directional communications between PC and peripheral, requires both high quality connectors and a specialized wire-type to handle the increased data rates.
Product Description | C2G parallel cable - 2 m | Type | Parallel cable | Technology | Double shielded twisted pair | Features | Molded | Length | 2 m | Connector | DB-25 - male | Connector (Second End) | DB-25 - male | Compliant Standards | RoHS |
General | |
Shielding Material | Foil with braid |
Features | Molded |
Length | 2 m |
Connectivity | |
Connector | 25 pin D-Sub (DB-25) - male |
Connector (Second End) | 25 pin D-Sub (DB-25) - male |
Miscellaneous | |
Compliant Standards | IEEE-1284, RoHS |
