We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a HDTV or projector which accepts a HDMI input. This cable carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirements of high performance applications.
Product Description | C2G 2m DisplayPort to HDMI Adapter Cable - Black - adapter cable - DisplayPort / HDMI - 2 m | Cable | Adapter cable - DisplayPort / HDMI | Technology | Shielded | American Wire Gauge (AWG) | 30 | Length | 2 m | Colour | Black | Connector | DisplayPort - male | Connector (Second End) | HDMI - male | Compliant Standards | DisplayPort 1.2 | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Adapter cable |
Interface Supported | DisplayPort / HDMI |
Jacket Material | PVC |
Shielding Material | Aluminum mylar foil with braid |
Length | 2 m |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
