We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a HDTV or projector which accepts a HDMI input. This adapter converter carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirements of high performance applications.
Product Description | C2G 20cm Mini DisplayPort to HDMI Adapter - Thunderbolt to HDMI Converter M/F - Black - DisplayPort cable - 20 cm | Type | DisplayPort cable | Length | 20 cm | Connector | Mini DisplayPort - male | Connector (Second End) | HDMI - female | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Length | 20 cm |
Colour | Black |
Connectivity | |
Connector (Second End) | 19 pin HDMI Type A - female |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
