We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a HDTV or projector which accepts a HDMI input. This adapter converter carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirement of high performance applications.
Product Description | C2G 20cm DisplayPort to HDMI Adapter - DP Male to HDMI Female - Black - DisplayPort cable - 20 cm | Type | DisplayPort cable | Length | 20 cm | Connector | DisplayPort - male | Connector (Second End) | HDMI - female | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Shielding Material | Aluminum mylar foil with braid |
American Wire Gauge (AWG) | 30 |
Length | 20 cm |
Colour | Black |
Connectivity | |
Connector | 20 pin DisplayPort - male |
Connector (Second End) | 19 pin HDMI Type A - female |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
