We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The TruLink USB 2.0 Active Extension Cable is perfect when you need extra distance; this cable will extend the reach of your USB 2.0 cable or device 12m (40'). The USB active extension cable actively buffers the incoming and outgoing signals to ensure compliance with the USB 2.0 specification for electrical and timing minimums. Both low and high speed USB devices will function equally well with this cable. Great for extending the reach to your USB devices.
Product Description | C2G TruLink USB 2.0 Active Extension Cable - USB extension cable - USB to USB - 12 m | Type | USB extension cable | Features | Active cable (signal regeneration) | Length | 12 m | Connector | 4 pin USB Type A - female | Connector (Second End) | 4 pin USB Type A - male | Compliant Standards | USB / USB 2.0 | Manufacturer Warranty | 1-year warranty |
General | |
Length | 12 m |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB / USB 2.0, Plug and Play, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | 1-year warranty |
