We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Why run cables for RS-232 control of your audio/video system, when you can use this easy adapter? The Velocity RS-232 adapter leverages your DB9 or 3.5 mm stereo audio cable to run 3-conductor RS-232 control signals between your control unit and your video display. Fully molded DB9 and 3.5 mm connectors provide excellent strain relief. This adapter is ideal for use with computers, projectors, and any control unit/display requiring 3-conductor RS-232 serial control.
Product Description | C2G Velocity DB9 Male to 3.5mm Male Adapter Cable - serial cable - mini-phone stereo 3.5 mm to DB-9 - 50 cm | Type | Serial cable | Features | Molded, thumbscrews, strain relief | Length | 50 cm | Connector | Mini-phone stereo 3.5 mm - male | Connector (Second End) | 9 pin D-Sub (DB-9) - male | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
Length | 50 cm |
Colour | Black |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
